Hello all,
i have an old vdb sequence i exported from houdini some years ago, it contains Density, Vel, and Temperature fields, but i've lost the original hip file.
Do you know if there is a way to use the gasupres solver with a vdb sequence?
I can't find any answer about this topic.
Could you help me please?
Thank you
VDB Upres
2976 2 0-
- deremis
- 9 posts
- Enivob
- 2658 posts
You might be able to convert them to standard volumes, supply the @timescale=1.0 as a detail parameter and feed that to the input of a dopnetwork that contains a gas upres network. You'll still need to supply some form of sourcing, however. You'll have to remember how your old file was setup.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- deremis
- 9 posts
