Python coding VSCode or Eclipse and USD
   2484   2   2
I try to do some python coding with Houdini and USD to learn the concepts. Unfortunately I was unable to get any code completion. A very simple script like this:
from pxr import Usd, UsdGeom
stage = Usd.Stage.CreateNew('D:/UserDatenHaggi/Documents/coding/USD/precompiled/HelloWorld.usda')
xformPrim = UsdGeom.Xform.Define(stage, '/hello')
spherePrim = UsdGeom.Sphere.Define(stage, '/hello/world')
stage.GetRootLayer().Save()
Works fine from Eclipse or VSCode with python path set to Houdini installation, but for some reason I do not get any code completion what is relly annoying. Does someone has any hints what I could to do get it? From within Houdini the code completion in the python shell works fine.
You need Animal Logic's VS ode Usd extension for code completion to work.
https://marketplace.visualstudio.com/items?itemName=AnimalLogic.vscode-usda-syntax [marketplace.visualstudio.com]
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
Thanks, that's indeed really hepful if I want to edit USDA code directly but I want to work with python and code completion.
