Currently I have an issue when trying to invoke the Tasks menu option: Task Graph Display Options… Unfortunately it just appears one time then it doesn't show up the next time. Attached is a gift that demonstrate that, it also troughs a python console error.
Thanks,
Alejandro
Houdini 18.5.351
Ubuntu 18.04
Task Graph Display Options.... Bug?
2860 2 1-
- Alejandro Echeverry
- 691 posts
Edited by Alejandro Echeverry - Oct. 23, 2020 08:34:50
- tpetrick
- 616 posts
The issue will be fixed in the next daily build. In the mean time, you can work around it by accessing the task graph options through the regular Network Editor Display Options. If you press the ‘d’ key in the network editor, the dialog that comes up will have a Task Graph tab on it with the same preferences.
- 691 posts
tpetrick
Thanks!! Yeah I was doing that in the meantime! I also noticed some heavy performance drops when TOPs shows you work item dependencies, mainly when dealing with heavy amounts of them.
Thanks tpetrick!
Edited by Alejandro Echeverry - Oct. 23, 2020 12:15:08
