newbie: should I be getting camera bug in 18.5 karma render?
   5465   6   1
Am I doing something wrong? When I try adding a camera to lop network I get:
File “<stdin>”, line 1, in <module>
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.351/houdini/python2.7libs\viewerstate\utils.py”, line 475, in sceneViewerFromPath
raise hou.Error(“Could not create a scene viewer with path: %s (%d)” % (pane_path,pane.type()))
TypeError: %d format: a number is required, not EnumValue
As there isnt an immediate answer, I should add this is on Houdinie 18.5.351, with the current betas for Redshift and Octane installed, and that might be what is causing the problem.
ErnestLeonardoMeyer
does your desktop have no scene viewer? I haven't been able to recreated this problem.
It's showing the opengl scene from a camera at the obj level, but nothing shows up in the lop yet because Im still building it
This seems very closely related to https://www.sidefx.com/forum/topic/76251/?page=1#post-326061, [www.sidefx.com] but your exception is being generated one line earlier in the python script… I would assume these two are related, but we'll have to try to reproduce the problem locally to be sure.
ErnestLeonardoMeyer
Hi Ernesto! You could help us by logging a bug and giving us the steps to reproduce this issue. We're creating and deleting cameras and looking through them and not seeing the error but we know you're hitting it. We just have to figure out what you're doing that's different from us. Thanks!
https://www.sidefx.com/forum/topic/15604/ [www.sidefx.com]
Chris McSpurren
I was getting the same issue on 18.5.3 but not in 18.5.4
Edited by DirtPizza - March 17, 2021 12:52:58
