Parent / Constrain a group of points to a transform...
   1863   2   0
…at SOP level.
Hi everyone.
So I have geometry coming in through alembic, and I can isolate the nulls I want to use as drivers. I also have some splines coming in that I would like to run through a vellum sim. I want to pin / constrain the ends of these splines to the nulls that are animated but can't figure out how at the sop level.
Do I need a wrangle or VOP or is there a simpler method that I'm missing?
groups?
Drasko Ivezic
groups?
Ok, now that we have that sorted… how can you make that group of points follow the transform of an alembic node, maintaining the offsets and getting the correct translation and rotation?
