Random seed value per copy in for each loop
   3590   2   0
Hi, I would like to copy a line with a point jitter to points on a grid and randomize the seed value of the jitter per copy.
I've been able to randomize the scale of the jitter but can't get the seed to work, any help would be greatly appreciated!
use @primnum as seed
(I think the jitter axis scale should be 1,0,1 as after the lines have been copied into place, they are pointing up, so you'd want to jitter them in x and z axis…but then who knows, you might want to jitter them in ALL axis, up to you)
EDIT: actually, don't need it at all…anyway, best you upload your file otherwise I'm wasting my time going down the wrong path.
Edited by vusta - Nov. 13, 2020 18:53:57
Thank you so much for the reply! I ended up figuring it out by watching Jeff Wagner's one tutorial. I had to create two metadata nodes and then set the one with the incoming geo to “Fetch Input”. I used it to create the rickety variation on the struts under this dock. Cheers!
