change displayColor with attWrangle
   4391   6   1
Hello guys.
I'm trying to port some custom HDAs into Solaris and i struggle even with simple VEX expression to change displayColor
Anyone would be able to help how to change the displayColor with VEX?
I managed to get to this stage, but that creates different type (color3f), then then USD displayColor expects (color3f).
I just was not able to get the correct type, thus the Array
string att_name =chs("att_name");
string primitive = chs("primpattern");
usd_addprimvar(0, primitive, att_name, "color3f[]", "constant");
usd_setprimvar(0, primitive, att_name,  vector[] (array({0,0,0},{0,0,0} , {1,1,1})));
Edited by martinkindl83 - Nov. 17, 2020 01:29:16
I find it's easier to use bound attributes rather than the usd functions directly. For really fancy stuff (large per vertex arrays) it's much easier and probably more performant too to use sops.
lop_wrangle_displayColor.hip (221.3 KB)
Thank you.
Would this work for alembic brought by file node as well?
martinkindl83
Thank you.
All data in USD is fair game, except for primitives that are children of an instanceable primitive.
By file node do you mean sublayer or reference lop?
jsmack
Originally i was using Alembic node at sops and sopimporting. You mentioned its not the right way how to bring alembic, so i tried File, which is by looking at the name Sublayer node.
Thank you for the example, it worked as expected
usd_setprimvar(0, primitive, att_name,  vector[](array({0,1,0})));
also why are you having second line in the vex? is it just safety thing?
As it looks, like the first line already creates constant interpolation.
v[]@primvars:displayColor = array(vector(rand(@elemnum)));
usd_setprimvarinterpolation(0, @primpath, "displayColor", "constant");
