Rendering Pyro new "Configure GPU Explosion" in Redshift
2346 2 0-
- animationalex
- 58 posts
I followed Entagmas video about the new work flow for the real time pyro set up https://www.youtube.com/watch?v=NG3bWfn9g7E&list=PLdFfFRXT0K_ghEfsSBnUUHw8mTrWr2hXb&index=4&t=633s&ab_channel=Entagma [www.youtube.com] . However I cannot get it to render in Redshift. It will render as a volume, but the shader on it does nothing. I can effect density with a volume wrangle, but it is still flat without a working shader. I unchecked “Minimal OpenCL Solve”, as well as trying to convert it to a VDB, but nothing works. Mantra, of course is fine, even when bringing it into a pre 18.5 scene. Any help would be appreciated.
- tamte
- 9380 posts
Not sure if related, bit be aware that Pyro Solver SOP (new in 18.0) as well as Pyro Post Process SOP internally attaches material using s@shop_materialpath attribute
Which would override any object level material assignment
So make sure to either remove this attribute or use Material SOP to override it with your Redshift material
- animationalex
- 58 posts
tamte
That was it, thank you so much!
