shotgun server begin
3095 8 0-
- uxrnme
- 10 posts
Hi Folks,
this does not seem to work , maybe i have wrong inputs ,
when i drop a python script node it works
this works…. in tops
import shotgun_api3
import os
SERVER_PATH = "https://user.shotgunstudio.com [user.shotgunstudio.com]“
sg = shotgun_api3.Shotgun(SERVER_PATH,
login = os.environ square barces ”PDG_SHOTGUN_LOGIN“ square barces,
password = os.environ square barces ”PDG_SHOTGUN_PASSWORD" square barces)
but when i add, shotgun server begin pdg node to connect to shotgun does not work
in the shotgun url when i enter https://user.shotgunstudio.com [user.shotgunstudio.com] , nothing seems to happen
and i have a pythonrc.py file
with these entries
os.environ square barces “PDG_SHOTGUN_LOGIN” square braces = “login”
os.environ square barces “PDG_SHOTGUN_PASSWORD” square barces = “password”
and this resides in dir:/documents/h18.5/pythonrc.py
have added this in houdini.env as well
HOUDINI_PDG_SHOTGUN_LOGIN = “login”
HOUDINI_PDG_SHOTGUN_PASSWORD = “password”
help needed
Thanks in advance
import shotgun_api3
import os
with these entries
help needed
Thanks in advance
Edited by uxrnme - Nov. 20, 2020 17:05:06
- johnmather
- 655 posts
To start, try the following:
What is the result?
- Create a Shotgun command chain.
- Set the Shotgun URL in the shotgunserver_begin1 node.
- Create an environment edit node and plug it into shotgunserver_begin1.
- Set PDG_SHOTGUN_LOGIN and PDG_SHOTGUN_PASSWORD to their respective values within the environment edit node. (Should look the the attached image)
- Select the shotgunserver_end1 node and press Shift+V to cook the network.
What is the result?
Edited by johnmather - Nov. 23, 2020 10:25:06
- uxrnme
- 10 posts
- johnmather
- 655 posts
- uxrnme
- 10 posts
- uxrnme
- 10 posts
- uxrnme
- 10 posts
- johnmather
- 655 posts
- uxrnme
- 10 posts
