Loop over work-items in partition in Python script node
   1498   1   0
Hi!
How do I access all the work-items in a partition in a python script node?
I'm using a custom python bin and cooking out of process, but can't even get this to work with the default python script node.
Ideally I'd use something like:
for items in partition:
#do something
Any help would be much appreciated!
You can access the contents of an upstream partition using parent_item.partitionItems if you're cooking in-process. If you're cooking out of process, there currently is no way to access data outside of the work item associated with the script.
Edited by tpetrick - Dec. 14, 2020 10:55:15
