Fatal error when rendering
   3811   2   0
Hi guys, I install indie on another machine and get this problem
I cannot render any thing and the principle shader even does not preview texture in viewport even I check the "use texture" square box.
Problem:
1.Tried render a grid, without principle shader, with a environment light with a 800MB HDR image. Failed
2.Tried render a grid. with a principle shader with a texture, with a environment light with a 800MB HDR image. Failed
23056: Fatal error: Segmentation fault
-- TRACEBACK BEGIN --
Traceback from mantra 18.5.408 (Compiled on windows-x86_64-cl19.16):
CURRENT THREAD 20292
+0x11b801ef C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x11b7ff0c C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x117c683a C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x11b013c4 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x7ffb1fa9bf83 C:\Windows\System32\ucrtbase.dll
+0x140004ca9 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\mantra.exe
+0x7ffb1774b900 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\VCRUNTIME140.dll
+0x7ffb224c184f C:\Windows\SYSTEM32\ntdll.dll
+0x7ffb2248a889 C:\Windows\SYSTEM32\ntdll.dll
+0x7ffb224c04be C:\Windows\SYSTEM32\ntdll.dll
+0x7ffabbb95cf4 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\OpenImageIO_sidefx.dll
+0x7ffabbb92617 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\OpenImageIO_sidefx.dll
+0x7ffabbb96f1b C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\OpenImageIO_sidefx.dll
+0x7ffabbba369c C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\OpenImageIO_sidefx.dll
+0x1b129988 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libTIL.dll
+0x10727df2 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x1075c9fb C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x1075c804 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x107c26f3 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x107c4086 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x107c5b7b C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x107cbe06 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x10805d85 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x0446ec8a C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x0445b1e5 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x0446d4fa C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x0446bf90 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x0446f20d C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libCMD.dll
+0x10809e0a C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libRAY.dll
+0x140002752 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\mantra.exe
+0x140003ea0 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\mantra.exe
+0x7ffb205b7c24 C:\Windows\System32\KERNEL32.DLL
+0x7ffb2248d4d1 C:\Windows\SYSTEM32\ntdll.dll
OTHER THREAD 23116
+0x7ffb224c0084 C:\Windows\SYSTEM32\ntdll.dll
+0x7ffb22453fe0 C:\Windows\SYSTEM32\ntdll.dll
OTHER THREAD 1508
OTHER THREAD 2584
OTHER THREAD 23120
+0x7ffb224bcd74 C:\Windows\SYSTEM32\ntdll.dll
+0x7ffb1f52fc21 C:\Windows\System32\KERNELBASE.dll
+0x11bbbd58 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x11bbbccd C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x11bbbc59 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x7ffb1fa510b2 C:\Windows\System32\ucrtbase.dll
OTHER THREAD 20568
+0x7ffb224bc774 C:\Windows\SYSTEM32\ntdll.dll
+0x7ffb1f521e93 C:\Windows\System32\KERNELBASE.dll
+0x044ee242 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\tbb.dll
+0x044ee12b C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\tbb.dll
OTHER THREAD 16924
OTHER THREAD 3416
OTHER THREAD 20408
OTHER THREAD 19756
OTHER THREAD 8168
OTHER THREAD 19980
OTHER THREAD 20248
+0x2764996a C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libPDGD.dll
+0x11bb4e31 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
+0x11bb5239 C:\Program Files\Side Effects Software\Houdini 18.5.408\bin\libUT.dll
OTHER THREAD 20972
+0x7ffb224bc814 C:\Windows\SYSTEM32\ntdll.dll
+0x7ffb1eb20bf8 C:\Windows\System32\mswsock.dll
-- TRACEBACK END --
Uh.I guess it is the HDR image that causes problem.
Remove it and it is okay to render a flat grid.
How could it happen?
What is the relationship between an HDR and driver errors:/
goose7
goose7
The open image IO driver loads images that are in non-native formats. If it doesn't handle an exception in the image data properly, it could crash the whole render.
I would send the image along with the crash report as a bug to Sidefx. In the mean time, you could try converting the environment image to a native RAT format image and see if it has the same problem.
