Get/Set Reference File Paths in Stage Manager with Python
   2878   2   0
Hi
I'm working on a Python/PySide tool for getting/setting reference file paths. This is straight-forward when using Reference nodes. For example, the Python code would look something like:
import hou
import nodesearch
lop_network = hou.node('/stage')
matcher = nodesearch.NodeType('Reference')
found = matcher.nodes(lop_network, recursive=True, recurse_in_locked_nodes=False)
# Get file paths
paths = []
for node in found:
    num_files = node.parm('num_files').eval()
    for i in range(num_files):
        parm_name = 'filepath{}'.format(i + 1)
        path = node.parm(parm_name).eval()
        print('{node}/{parm}: {path}'.format(
            node=node.path(), parm=parm_name, path=path)
        paths.append(path)
# Set file paths
for node in found:
        node.parm(parm_name).set('$HIP/assets/asset.usd')
But how would I do this with Stage Manager nodes? They use a custom UI instead of the typical Houdini Node parm UI, and I can't find documentation for this.
Any ideas?
Only the UI is different. Under the hood the Stage Manager uses regular parameters like every other Houdini node. You can switch from the custom UI to the regular parameter dialog using the "Show/Hide Parameters" button immediately to the right of the node name in the parameter dialog pane. In other words, to manipulate the stage manager with HOM, you can use standard parameter manipulation methods.
Thank you mtucker! I didn't know about "Show/Hide Parameters". That is super helpful.
