How to loop feed Ray SOP in animation?
   2577   3   1
Hi.
I need to loop feed the result of Ray SOP in an animation:
- the collision primitive is animated
- points of input geometry should be re-projected every frame on the updated collision primitive
I tried to do this using CHOP's Feedback node (attached), but failed to set it up correctly. Does anyone know how to make that work or use any other way how to do it?
ray_feed.hipnc (89.9 KB)
OK, I went with just attributes for now. Interpolating Prim Num and Prim UVW attribute from the Ray node. Would like to know how to loop the ray though.
attribute interpolate.hipnc (106.6 KB)
you can use Solver SOP if you want to modify geometry result from previous frame
or For Loob With Feedback loop in SOPs if you want to just loop a few times within the same frame
tamte
Yes, that's probably the best tool for the job. Thanks.
