RBD interpenetration issue
   1629   1   2
I'm new to Houdini and was trying out a simple rigid body simulation example using RBD solver. The scene
is simply 5 cubes falling onto a plane. However when I simulate to 35th frame, as the scene becomes nearly static, then suddenly interpenetrating happens. Using larger number of collision passes seems not helpful.
Does anyone know what I need to change to make this work? Like stay static as it becomes.
RBD_5cubes.hipnc (318.7 KB)
Hi!
Set the Collision Geometry option for plane to Implicit Plane and boxes to Implicit Box with a little bit offset to fix this.
I highly recommend to use bullet solver instead because it is so faster than RBD Solver.
RBD_5cubes FIXED.hipnc (318.8 KB)
