How to set 'render with take' with an attribute?
   1723   0   0
I want to wedge multiple versions of something by using the take system in Houdini, and although the 'Render with take' parameter on a ROP node is a string attribute, I can't figure out how to drive it from a TOPs attribute. It only seems available as a drop-down menu with all available takes in it. How can I access this parameter as a string so that I can drive it from my TOPS net?
