RBD IO with TOP
   2253   4   1
I'm trying to process my caches with TOP, no problems for filecache, rop etc. but is there a way to process RBD IO with TOP ?
Thanks for your help
Capture d’écran 2021-02-07 192637.png (894.5 KB)
- David
It should be possible to point the ROP Fetch TOP to an RBD I/O node, and use it to create work item(s) that write the RBD I/O output to disk. Is that not working for you?
tpetrick
Yes I can but the rest geo is not saved
Capture d’écran 2021-02-09 184907.png (1.3 MB)
- David
Ah, I see. That's because saving the rest geometry is done with a special button, which isn't part of the regular interface for cooking a ROP or File Cache node. We'll have to add a special case to the ROP Fetch so that it can detect the RBD I/O node type and do that extra step.
I've logged an RFE for that issue.
tpetrick
ok gonna do this thanks
- David
