PointInstancer and Light Linking
   2037   2   1
I'm having some trouble with light linking on pointInstancer. Should the link be made on the prototypes or the pointInstancer primitive? Every combination I've tried is producing results I cannot fully understand so I thought I'd ask what the recommended procedure is or if this is something that is not supported by USD.
Thank you.
I would expect it to work only by linking to the entire point instancer prim, but sometimes details like this slip through the cracks so I also wouldn't be terribly shocked to learn that there are some bugs around this.
This is actually something on the Redshift side. I've posted about it on the Redshift forums. Karma seems to produce the expected results. Thank you.
