Hey guys,
I have a shader which has no opacity shader attached but when writing out the USD it seems to connect my diffuse to the opacity.
Its doing nothing when reading back into Solaris but when reading into Unreal engine, its causing all my asset materials to be set to Translucent instead of Opaque.
Any ideas on the cause?
Thanks all,
Dan
USD Connecting non-existent opacity texture
4260 4 0-
- danwnewlands
- 41 posts
- dkeraudren
- 11 posts
I have the same problem, and apparently it's seems to be a "feature" cause it's written in the material libray doc -> https://www.sidefx.com/docs/houdini/nodes/lop/materiallibrary.html [www.sidefx.com]
Unfortunately it's breaking a lot of things, even their magic market demo files broke when you rewrite the usd files in a newer version of Houdini...
- danwnewlands
- 41 posts
Daraminix
Ah yes, it says so here:
Note, if textures are involved, the auto-generated preview network will wire the alpha output of a USD Texture Reader primitive to the opacity input of a USD Preview Surface shader primitive. Some renderers, like Storm, are known to mishandle the opacity, leading to artifacts in the viewport. To workaround such cases, you can turn this toggle off and then you can manually create a USD Preview network inside, feeding it to the Collect VOP along with the original surface shader.
It would be great if this could be optional and defaulted to off but there must be a good reason why its defaulted to on. Hopefully sidefx can clarify.
Thanks Daraminix
- jsmack
- 8197 posts
- rafal
- 1471 posts
