mm BurnOut v 1.5 to v2.0
   2066   0   1
Hi there,
I did that...
Tool for Houdini 18.5 and up, not sure and not testing on Houdini 17.5
With this HDA you can create a dust/smoke simulation so quickly (save 75% of the time comparative the traditional way).
With this tool, it’s possible to create a smoke/dust effect between objects and a collision between them. Very useful for creating trails, for example, of cars on the sand, bodies/characters that run and touch the ground, or elements that fall and raise dust.
Introduction video and samples video here
New features in release 1.5
  • Unlock/open HDA
  • Toggle show emitter geometry
  • Toggle show pyro emitter
  • Toggle enable/disable Noise on pyro emitter
  • Toggle switch to VDB cache
  • Improved Boundaries and show grids with voxel resolution
  • Improved interface for Fields when you save the bgeo cache
  • Improved documentation
HDA was developed on Houdini 17.5 and finalized on Houdini 18.5, I want to improve it soon and add some features like the sparse solver and the compatibility with TOPs.
C&C are welcome
Matteo
