Guide Groom plant guides: no segments! SOLVED
   2256   1   0
Hi!
I'm using the guidegroom node to plant guides. I set the Default Segments to 8 but when I create guides, they each have only 2 points. What could cause this?
-Olivier
Edited by olivierth - March 3, 2021 12:06:02
Ohh! ok, I just found out. Since I wanted to place the guides manually, I set the guidegroom1 top node's density to zero. That was causing the problem.
Now that I set the density just high enough to have one guide before I start planting guides, it now works. But the number of segments is not linked to the setting like in the image. It actually uses the top node's "Segments" setting.
