Hey,
Are there any examples of how you would run a PDG script from terminal or an external program via python, with a defined input file.
I my head I'm imagining something like opening a terminal (linux) and doing a command like: houdinipdg -pathtograph /path/to/pdgnetwork/network.hip -inputfile /path/to/file/file.abc
..and then the pdg network would use that file path as an input to the graph to create a turntable for instance
Any tutorial links or examples would be appreciated to get me going
Command line process PDG with custom input
4156 4 0-
- danwnewlands
- 41 posts
- tpetrick
- 616 posts
You can cook a TOP network from the command line using Hython or HBatch -- there are some examples here: https://www.sidefx.com/docs/houdini/tops/cooking.html#cookcommandline [www.sidefx.com]
Input files would need to be sent as environment variables, not as extra command line arguments, and then referenced in the .hip file as such.
- danwnewlands
- 41 posts
tpetrick
Perfect, this got me where I needed to go! Thanks pal
- danwnewlands
- 41 posts
tpetrick
So just coming back to this, I've got things working in terms of launching a script and executing a network with the various commands etc but I need to define custom variables at launch for instance $FOO = "bar" so that I can use $FOO in my script and expect a value to be supplied.
Usually we would `export FOO="bar"` I guess but I cant seem to find anything in the docs to do this with hbatch.
Cheers!
Edited by danwnewlands - March 23, 2021 13:33:22
- tpetrick
- 616 posts
Environment variables you set in your shell should be inherited by the hbatch session. From within hbatch you can set them using the set command: https://www.sidefx.com/docs/houdini/commands/set.html [www.sidefx.com]
