can I or how do I edit an HDA parameter?
3130 3 1-
- bobc4d
- 327 posts
- tamte
- 9417 posts
you are probably doing Edit Parameter Interface, which is just for editing spare parameters on the node instance
to edit UI of HDA definition and other stuff you can do either
RMB (on the node)/Type Properties..
or
select node and choose Assets/Edit Asset Properties.../your asset
or
- bobc4d
- 327 posts
- leifdux
- 3 posts
tamte
or
This worked thank you! I was confusing myself between Edit Parameter and Type Properties!
