Edit parameter interface – can't seem to read string attrib
1911 2 0-
- benek
- 49 posts
I'm just trying to create a custom parameter interface to read some string attributes from a geometry node, but for some reason I can't make it read string attribs, but it works fine with float attribs. I've obviously got something wrong somewhere, but cannot figure out where. I would be grateful if anyone is able to take a quick look…
Edited by benek - March 23, 2021 07:28:56
- Enivob
- 2658 posts
Not sure what the issue is. You are creating the attributes under the detail context, and they show up. Just remember that some function calls to fetch string attributes have a trailing "s" added to them. To fetch a float you might use point, to fetch a string you would need to use points the trailing "s" denotes operating upon a string instead of a number.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- benek
- 49 posts
