Houdini console error
   2749   1   0
hi,
I can't figure out what this message is.
And I can't see Node Information by Useing Middle Click,
This error refuse me to do so.(houdini version 18.5.408)
Please tell me whatever you know.
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\nodegraph.py", line 167, in handleEventCoroutine
pending_actions)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\nodegraph.py", line 1248, in handleEvent
uievent.editor, output_index)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\nodegraphui.py", line 966, in createInfoWindow
force_cook, output_index)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\nodegraphui.py", line 441, in display
self.update(node, pinnable, recook, output_index)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\nodegraphui.py", line 494, in update
verbose=verbose, debug=debug)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\nodegraphui.py", line 169, in update
templatefile, showall=self.showall, **kwargs
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.408/houdini/python2.7libs\baseinfowindow.py", line 289, in update
template = theTemplates.get_template(templatefile)
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\mako\lookup.py", line 85, in get_template
return self.__load(srcfile, uri)
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\mako\lookup.py", line 127, in __load
self.__collection = Template(uri=uri, filename=posixpath.normpath(filename), lookup=self, module_filenameself.modulename_callable is not None and self.modulename_callable(filename, uri) or None), **self.template_args)
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\mako\template.py", line 93, in __init__
(code, module) = _compile_text(self, file(filename).read(), filename)
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\mako\template.py", line 265, in _compile_text
exec code in module.__dict__, module.__dict__
File "basic_mako", line 1, in <module>
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\mako\cache.py", line 4, in <module>
from beaker import cache
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\beaker\cache.py", line 10, in <module>
import pkg_resources
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\pkg_resources.py", line 2594, in <module>
_declare_state('object', working_set = WorkingSet())
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\pkg_resources.py", line 425, in __init__
self.add_entry(entry)
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\pkg_resources.py", line 440, in add_entry
for dist in find_distributions(entry, True):
File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.408\python27\lib\site-packages\pkg_resources.py", line 1700, in find_on_path
for entry in os.listdir(path_item):
More info please. What are you trying to do when this happens? What obj/sop are you using?
Sean Lewkiw
Machine FX - Cinesite MTL
