Importing a VDB and getting a velocity from said VDB
   4670   5   1
Hey guys! i'll keep it succinct.
i'm trying to advect some particles via a VDB I've imported from Embergen.
I've imported a VDB with the purpose of having it advect some particles I've made from my pop network it looks like this
, and it has THESE attributes.
As you can see, it has velocity in the x y and z. However in the Advect by volume node in my pop network.
The field name for the source is just Vel
So that makes me wonder, do I need to tell Houdini that the velocity's I've brought in, are assigned to vel? if so. How do I do that?
http://paulmillerart.com/ [paulmillerart.com]
In this case, it's just asking what the field is called in your source so just use velocity as it's called in your volume.
First, though, the velocity field names don't appear to be in the typical format for Houdini - you'll probably want to use a name SOP to rename the volumes, substituting periods in place of the underscore (or change it to vel.x etc and then leave the parameter in popadvectbyvolumes at default)
nice 1. April post...
for all others: floattovec in an attribvop
VDB vector merge.
hey guys! Just wanted to thank you for the help! I wasnt able to get back to this at the time, But again. Thank you.
hey man - sorry to necro this post - maybe you already figured it out
the embergen co-sys is a real pain in the ass
first you need to convert the embergen volume - convertvdb set to 32bit float
followed by a volume wrangle to re-orient the scalar vectors within the sim to work with Houdini's:
float vx = f@velocity_x;
float vy = f@velocity_y;
float vz = f@velocity_z;
// EmberGen Z-up → Houdini Y-up (right-handed)
f@velocity_x = vx;
f@velocity_y = vz; // Z becomes Y
f@velocity_z = -vy; // Y becomes -Z to keep handedness
then i used a vdbvectormerge to combine all the scalars into a "vel" attrib
from here, it should just work
