Why does my smoke look blocky like this?
4880 4 1-
- REO_3D
- 4 posts
- ianoreo
- 8 posts
- REO_3D
- 4 posts
ianoreoNo, I already thought about that, it has ample room, in fact the padding I have is a little too much but I kept it like that just to be sure.
Are you hitting the edge of your smoke object's container? The automatic resizing node sometimes needs some adjustments and may accidentally clip your sim at the edges.
- asm
- 31 posts
- REO_3D
- 4 posts
All right I found the problem. You see I was sourcing each smoke trail from a single moving particle that I Rasterized, when you do that houdini simply creates a square volume (it's size is @pscale) around that particle, now if your smoke Density Scale is too high or if the brightness is too high then the edges of the generated square will begin to show up.
The solution is to not source from a single moving particle but from a sphere or some other geometry. Then no matter how bright your smoke is no artifact will show up.
Thanks everybody for your help.
Edited by REO_3D - April 4, 2021 12:08:38
