I use a group expression node to create a group that has density greater than .5.
@density > 0.5
From a menu I select the attribute 'pressure'. I would like the group expression to reference the menu item and change the group expression to @pressure > 0.5.
I tried @'...relative path to menu selection' > 0.5
I tried a few things to try to reference the string name of the selected attribute and use it in a vex expression. I assume this is easy and I am missing something obvious, but right now I can't figure it out.
access attribute value from string
2528 3 1-
- bjcarve
- 30 posts
- bjcarve
- 30 posts
I add this to a node's parameters
from itertools import chain
node = hou.pwd()
geo = node.geometry()
attribs =
return list(chain(*zip(attribs, attribs)))
I now have a menu with all of the point attributes from the Geometry spreadsheet, listed with an @. For example I can select "@pressure".
If I copy parameter and paste relative reference, I get something like the following
'chs("../scaleData/menuItem")'
This string is "@pressure".
In vex if I enter @pressure in an expression, the pressure value for a point will be loaded.
If I place a reference to a string, vex will say invalid source.
Any suggestions? Ultimately, I just want the user to select what attribute to visualize.
node = hou.pwd()
attribs =
- tamte
- 9378 posts
- bjcarve
- 30 posts
I have not used the bindings tab in the Attribute Wrangle.
Thanks for the great suggestion.
I figured out how this works and will use it in the future.
But, I am having trouble referencing the parameter from the menu selection.
I tried copying the menu item parameter. `chs("../null1/point_attribs")`
I then pasted relative reference to "Attribute Name" in the bindings tab.
I get "Bad parameter reference". But if I typing pressure and a VEX parameter, I can use the Vex Parameter in my vex expressions.
