Voronoi Fracture Fills Hollow Space on Concave Geometry
   1882   2   1
Hi everyone !
I'm having issues with the voronoi fracture on concave geometry.
I'm trying to fracture a pillar which was created in C4D. To do so, I create a VDB and scatter points in it, then I use the Voronoi Fracture SOP on the base geometry. It works quite well overall, however on some curved concave areas the voronoi fracture fills the hollow space, which I would like to avoid.
You can see the problem on these pictures :
On the second picture the darker parts of the fracture fill the hollow space. I would like to get rid of these artifacts.
Does anyone know how to fix this issue ?
Thanks !
PS I have not attached the .hip file since it's based on a heavy alembic file, but I can do so if necessary.
Is your original geo watertight with no open edges?
Hello tamte,
That was the issue indeed. The geo was created with a C4D boolean, which by default outputs two different geometry pieces. I fixed it, and it works fine now !
Thanks for your answer
