install OCIO.config
   5651   5   4
Hello
This is my first post I hope it's not out of place. I have been reading a lot here as I have been learning houdini in my free time for a couple of months. Great community, hopefully there will be someone to help me with this!
I am trying to install my ocio config without much success!
I dl the config from here ; https://github.com/imageworks/OpenColorIO-Configs [github.com]
Took the ocio.config out of the latest version (1.0.3), placed it locally (C/Users/.../houdini18.0/OCIO)
I edited (and saved!) my houdini.env (added ; OCIO = "C/Users/.../houdini18.0/OCIO/config.ocio")
When I launch Houdini I have a list of errors returned (invalid colorprofiles).
Now I am new to Houdini so admittedly there might be some user's mistake somewhere!
Using Houdini 18.0.499 and my scene uses Arnold.
Thanks a lot for taking the time to help me!
PS ; also tried to load from edit / color settings / color correction without success.
Edited by Anissa_s - April 29, 2021 13:50:41
The docs mention you're not supposed to set OCIO from within houdini.env. You'll want to configure your system environment to do this instead.
You can either set the variable globally (control panel > system > advanced > environment variables), or if you value a little more flexibility, you can write a quick batch script that sets the OCIO variable and then launches Houdini from that same shell process. The advantage of doing it this way is that you can more easily choose whether or not you want to be using OCIO for individual jobs. Here's what my houdini_18_ACES.batlooks like:
SET OCIO=D:\Projects\VFX\OpenColorIO-Configs\aces_1.1\config.ocio
"C:\Program Files\Side Effects Software\Houdini 18.5.462\bin\houdinifx.exe"
Hey
Thanks a lot for your quick answer!
I just tried the batch script solution, unfortunately I get the same error returned. I have to run now but will try the first option as soon as I have some time.
Did you download the LUTs as well? It sounds like it can't find definitions for the color spaces included in the config.
Anyway, give the attached config a try. I created it based on ACES 1.2 for my own convenience. I'm not a color expert, so no guarantees! But I've been using it for a few weeks and it's working well. It basically cuts out all the nonsense that comes with OCIO by default, leaving only the essentials for CG.
Just extract to your folder of choice and point Houdini to it (either via .env or system-wide) and you should be all set.
Edited by BrianHanke - April 29, 2021 14:36:08
brian.ocio.zip (10.3 MB)
Hey Brian!
It worked!
I appreciate you share your config, really nice to have just the ones we need
Thanks a lot for your help
Gui_89
Hey Brian!
It worked!
Great, glad to hear!
