Are instanced USDSkels supported?
   2116   1   1
Hi
I am reading in the example usdskel asset setup from pixar
I can play the animations on the 3 characters using the original file, but when I switch them to be instanced, then they are just displayed in T-pose and there is no animation.
Is this a known limitation? I am trying to create my own instanced USDSkel based sims but wanted to try and get this basic example working first
I've attached the original and instanced example setups:
Loading HumanFemale.noninstanced.usda does work (anim from frame 100)
Loading HumanFemale.instanced.usda doesnt work
both work in usdview
thanks
USDSkel_instancing.zip (14.0 MB)
Support for instanced skels was added in USD 20.11, so this won't work in Houdini 18.5 which is using 20.08
