Can't get hou.SimpleDrawable to display in SOP context.
   2337   4   0
I'm trying to simply display a hou.SimpleDrawable in an otherwise empty asset on SOP level, basicly following the documentation example here [www.sidefx.com].
So all I have is this code in the Viewer State of an asset with a Null inside labeled "GET_INPUT" connected to the first input and nothing connected to the output.
class State(object):
    def __init__(self, state_name, scene_viewer):
        self.state_name = state_name
        self.scene_viewer = scene_viewer
    def onDraw(self, kwargs):
        """ Called for rendering a state e.g. required for
        hou.AdvancedDrawable objects
        draw_handle = kwargs["draw_handle"]
        geo = kwargs["node"].node("GET_INPUT").geometry()
        drawable = hou.SimpleDrawable(self.scene_viewer, geo, "drawable")
        drawable.setDisplayMode(hou.drawableDisplayMode.WireframeMode)
        drawable.setWireframeColor(hou.Color(1.0,0.0,0.0))
        drawable.enable(True)
        drawable.show(True)
def createViewerStateTemplate():
    """ Mandatory entry point to create and return the viewer state
        template to register. """
    state_typename = kwargs["type"].definition().sections()["DefaultState"].contents()
    state_label = "SimpleDrawable test"
    state_cat = hou.sopNodeTypeCategory()
    template = hou.ViewerStateTemplate(state_typename, state_label, state_cat)
    template.bindFactory(State)
    template.bindIcon(kwargs["type"].icon())
    return template
I would expect to see the geometry connected to the first input of the asset to be displayed as a wireframe when I select the node and press enter in the viewport, but nothing shows up.
Could someone shed some light on what else I need to be doing with the SimpleDrawable to display correctly?
Edited by gorrod - May 24, 2021 15:05:22
onDraw is normally used for drawing advanced drawables (e.g. hou.GeometryDrawable). hou.SimpleDrawable is rendered by the viewer, there is no need for an onDraw callback. For instance, you could create your simple drawable in the __init__ method, enable it in onEnter, disable it in onInterrupt, re-enable it in onResume and so on.
Check out the simple_drawable.hip demo scene which provides a more detailed scene setup.
Thanks a lot, that does the trick already.
I will certainly take a look into the demo scene!
Could you point me, where I can find this simple_drawable.hip demo scene?
wolskikrzys
In H19, you can load the examples from the Viewer State Browser file menu and load the scene from the Demo Viewer States shelf or load the scene from $HH/viewer_states/examples if you're in H18.5 or previous versions.
