Question about Houdini's Skininng...
2623 3 0-
- kriegmesser74
- 41 posts
- kriegmesser74
- 41 posts
- tamte
- 9423 posts
You can use any object as long as it has Capture Region SOP as those are essentially whats used in bones also
But nowadays I'd suggest you using KineFX as that's built around the idea that joints are represented as points and bones as lines, so technically it will be straightforward to use CVs of your nurbs curve if you resample it and ensure correct transform attributes are present
- kriegmesser74
- 41 posts
Oookaaay, I need to clear things up a bit... It's about facial rigging, the idea is to have nurbs curves with bones (or other objects whatever)attached to their CV's in world space (properly/uniformly oriented), and to drive nurbs deformations trough morphs (extreme poses) so the nurbs act like facial muscles, and in the end to balance those combinations of morphs trough the "joystick" (i.e. a circle shape in the box shape, limited not to abandon boundaries of the box shape, with the value of 0 to 1). I've done this many times, in Max or Maya... in Maya you would go to node editor and connect CV's WorldPositions to joints position... where do I need to go in Houdini to achieve this... maybe Chops? How would a network look like for one CV and one bone?
