Trigger Animation on Event
   2598   5   1
Hi, I wonder if it is possible to trigger an animation on an event.
Let's say I have a sphere, I simulate it falling on the ground just using a Dopnet and a ground plane as a static object.
And let's say I want to play an animation each time the sphere touch the ground, like waves on some water.
How can I do it ?
I've heard of RBD Impact Analysis, but I can't find how to use the generated points for something like it ?
Can someone help me ?
And can I have an example file ?
I link an example of wave that I want to trigger when the sphere touch the ground
Sound_Wave_v001.hip (530.2 KB)
Up, no one has a clue on how to do it ?
https://forums.odforce.net/topic/27825-controlling-animated-instances/#comment-159083 [forums.odforce.net]
Any use?
Edited by Hatchery - June 14, 2021 07:12:20
Love Houdini
Hatchery
Any use?
It might be useful but I can't figure how to link this to a trigger from a CHOP..
Here is a solution. I first did it with CHOPs but it was way too complicated and still wouldn't work. This method uses a SOP solver and time offsets.
Be sure to re-cache the filecache node in "Wave_to_trigger" for this to work.
Also, had to switch to poly object for the dop impacts to work.
Edited by mrCatfish - June 16, 2021 14:59:29
Sound_Wave_v002.hipnc (592.7 KB)
Peek 2021-06-16 14-59.gif (79.0 KB)
Sean Lewkiw
Machine FX - Cinesite MTL
Oh that's fantastic and I'm sure will be really useful to know how to do
Love Houdini
