symmetrical loop cut and polygon loop
   2535   2   0
1) Is there an HDA that will provide symmetrical loop cuts? The lack of a symmetry option in poly split is a major limitation to modeling in Houdini. For example, if one makes a tube and wants to add loop cuts at the bottom and top 10%, one has to either use a workaround, like polyextrude caps, use clip and mirror nodes, or create one polysplit at 10% and the second at 100/9%.
2) Creating an edge loop is easy, as is converting edge/point/polygon selections but is there an easy way to select a polygon loop if one has selected two adjacent polygons? This is pretty standard in other 3D programs.
Edited by anon_user_38315714 - July 15, 2021 18:14:05
Two years later and this is still a frustration.
Mike_A
The frustration is real.
