Switch-like input connectors
   1428   0   0
I was wanting to make my own custom switch in ROPs in this case, but I believe the same applies elsewhere. Is it possible to show which input is 'active' (solid vs. dotted line)? In this example there happens to be a switch in the HDA but it seems the live input display is not propagated through subnets.
I did read the bit about reference inputs but am currently unsure how to set that other than manually in the operator type properties panel.
J
Edited by protean - Sept. 12, 2021 12:21:45
john
