ACES works, but not available in Redshift RenderView? (Mac)
   2323   2   1
So I have installed ACES via packages. And it works. (I get the Aces color correction toolbar controls and the pretty viewport)
However I do not get it in the Redshift RenderView, as I see it in tutorials. The render itself seems to be changed tho, and thus OCIO is doing something there.
This is how it looks on tutorials:
This is mine: (There are no options in those. Only 'ACES' in the above)
I first thought. Oh, Redshift need it separately. It should be a global environment variable instead of an Houdini environment variable.
So I made it an global environment variable, so that appears it OSX Terminal when I use the command: "echo $OCIO".
However, this did not load into Houdini. After putting the variable back into the packages json, it still did not appear in RedShift.
Also some Errors appear on the RedShift ROP. (See below)
What can I do?
Thanks in advance, :-)
Edited by OdFotan - Sept. 30, 2021 08:50:07
Screenshot 2021-09-30 at 09.54.41.png (8.9 KB)
Screenshot 2021-09-30 at 10.00.59.png (54.6 KB)
ROP errors.png (35.6 KB)
I've found that selecting the camera and re-adding the redshift CamParameters usually sorts it out.
How do you re-add those? (some older nodes in some scenes don't even have those rs tabs)
By creating a new node (after RS instalment), and copy over all the original parameter values?
Or is there a command for that?
Thanks,
EDIT: Ah, I see there's a command in the Redshift submenu on the main menu.. Will try that out.
Edited by OdFotan - Oct. 1, 2021 07:59:09
