Is it possible to do the following in a TOPs nukeserver command chain:
- nukeserver command chain begins
- tell nuke to do some stuff
- print some command from nuke back to houdini so that we get some feedback in the shell that launched houdini
eg
# render 1 at a time so we can still RPC for x in range (first_frame, last_frame+1): nuke.execute(write_node, x, x) ## we would want the following to echo back to the terminal print ('Rendering %s frame %s' % (write_node['file'].value() , str(x)))
