I have a usd file, exported from 3dsmax with one object which shows up in Houdini as expected with two materials.
When I import this file back into 3dsmax or Maya everything is fine and I get the two materials.
But when I try to build the same setup in Houdini, none of the materials show up in 3dsmax or Maya.
So I tried comparing the max-usd export to the houdini-usd to find out what's wrong but I have no idea.
My guess is that the assignment has to be done a bit different from what I am doing. (For whatever reason it works with only one material assigned...)
I also figured out that max/maya only eat their own export correctly by using the USD-Preview Shader...
I uploaded the three files, hoping that somebody could help me to figure out the difference or how to set it up correctly.
Felix
