Copy to Points (Instancing) crashes UE4.27
   4332   6   1
I don't know if this is a BUG or Im doing something wrong but is driving me crazy and keeps me away from making progress in my project.
I made a very simple HDA that takes a mesh as input (Object merge), then, it computes the boundaries of that mesh and see how many times that mesh fits in a spline (line), resample the line and use a copy to points to instance. The problem is, that if I use the 'Pack and Instance' option in the copy to points node, UE4 crashes. If I disable the option, HE gives me a new mesh as output but I want an instanced mesh as output, not a new static mesh.
However, if I use the attribute method everything works fine but I really want and need to use the object merge node.
If I supply a default houdini Box into the copy to points method, the hda works fin and ue4 doesn't crash the main problem is the object merge node because Im trying to import a mesh from unreal.
I have read the documentation and seen some YT videos, and Im pretty sure this is a bug.
Currently using UE4.27, Houdini Engine v2 and Houdini 18.5.696
Edited by CGToast - Oct. 22, 2021 10:54:32
Tested the HDA in a new project inside UE5.0 EA2, the HDA works fine so this is very likely a bug with 4.27
Yeah, I'm fighting with the same - in my case it crashes if packed mesh has a material attribute (unreal_material on primitive or detail before packing). Also crashed when using unreal static mesh reference directly from Unreal (both ways - pack before input or packing inside HDA before copying to points). This was definately working before in older versions!
Houdini 19.0.455 + Unreal 4.27.2
Edited by rendereverything - Dec. 10, 2021 08:22:56
I think this should be elevated to a very high priority - most Houdini Engine/Unreal workflows rely on instancing packed objects, so this kinda breaks almost everything!
Here is a simple test HDA attached if anyone wants to try.
By default it does not crash - you have to enable the checkbox "Enable Crash Scenario" to crash.
It demonstrates both ways of the crash:
1. If no static mesh is set in Instance Mesh parameter, it will use internally generated packed geometry (cube) with material attribute.
2. If you set a static mesh in Instance Mesh parameter it works, but as soon as you click "Pack before export" (or add pack node inside HDA - it does not matter), it will crash.
If "Enable Crash Scenario" is not checked - it will use plain packed geometry (sphere) without material attribute - and it works fine.
I'm using latest Unreal 4.27.2 and Houdini 19.0.455 (Crashes also in today's daily build 19.0.464).
instancecrasher.hdalc (8.3 KB)
For now the workaround is using attribute instancing using "unreal_instance" point attribute. This works fine, so something must be wrong with how copy_to_points is made into unreal instancer.
Facing this problem for year I guess. Still working on Houdini 18.5.532 - last version whitch works with instancing without crashes. Waiting to fix this problem a lot. How possible is many developers use this tool with such bug?
