Hi!
I'm simply trying to use a cops image to change my camera's background image (Arnold). First, I wanted to test it on a uvquickshade sop to make sure it works but I just can't get it to work. What am I doing wrong? This is about to drive me nuts!!
-Olivier
cops image to camera background?
2981 4 0-
- olivierth
- 1193 posts
- jsmack
- 8223 posts
- olivierth
- 1193 posts
- tamte
- 9540 posts
UV Quickshade usually works with op: referenced COPs like in your screenshot
just make sure your grid has uvs, or at least that UV Quickshade has appropriate axis picked up for creating fallback UVs
because based on your Screenshot if your grid is vertical (XY) you will not see much since you don't have uvs and UV Quickshade will project from top so potentially capturing just 1 row from your texture at most
if thats the case, either ensure explicit UVs on your grid (UV Texture) or switch UV Quickshade axis to X or Z axis depending on which way your grid is facing
- olivierth
- 1193 posts
