How to set the color of the construction plane?
   2284   3   0
The construction plane looks ok in front of a light background:
But it's basically unusable when the background is dark:
How to change the color of the construction plane?
Screenshot 2021-12-31 172100.png (305.7 KB)
Screenshot 2021-12-31 172153.png (1.0 MB)
There are color scheme files named 3DSceneColors (.dark .light .bw matching the viewport background color scheme) in Houdini 19.xx\houdini\config. You can copy them to Documents\houdini19.0\config folder and edit the "CplaneColor" value
raincole
Are you using a custom color theme?
That's not what color the construction plane is for me with a dark background, It's light gray.
PatW
Thank you very much. I'll try it.
jsmack
raincole
I honestly don't know how to use a custom color theme (before I read the answer above).
But I use an OCIO config, which changes the color correction of viewport... maybe that's the reason?
