Hi there! At work, I've got access to Houdini Master 19.0.383 (py3), and I've been trying to follow the below workflow for retargeting FBX animation:
https://www.sidefx.com/docs/houdini/character/kinefx/retargeting.html [www.sidefx.com]
However, none of the nodes they mention, Rig Match Pose, Map Points, Full Body IK, are available, and I have a Bone Deform node, instead of Joint Deform node. I couldn't find anything about this. Is there something I need to have downloaded, or an option I need to enable? Thanks for any help!
H19 missing FBX retargeting nodes??
2163 3 0-
- seven6ty
- 33 posts
- seven6ty
- 33 posts
Oh weird, I notice on start up, that I get the following notifications, in the Houdini Console popup:
opalias: 'kinefx::adapttoterrain' is not a known operator.
opalias: 'kinefx::fbikconfiguretargets' is not a known operator.
opalias: 'kinefx::rigdoctor' is not a known operator.
opalias: 'kinefx::rigmirrorpose' is not a known operator.
opalias: 'kinefx::rigpose' is not a known operator.
opalias: 'kinefx::skeleton' is not a known operator.
opalias: 'kinefx::parentjoints' is not a known operator.
opalias: 'kinefx::orientjoints' is not a known operator.
opalias: 'kinefx::configurejoints' is not a known operator.
opalias: 'kinefx::jointcapturebiharmonic' is not a known operator.
opalias: 'kinefx::' is not a known operator.
Would anyone know what causes this?
- mestela
- 1868 posts
- Magnus_Hagerman
- 1 posts
At work we've had similar experiences of missing hda definitions, and the cause of it is that the Houdini shortcut is using %HOMEDRIVE%%HOMEPATH% as start location (which did not work with our IT's set up). So you can either change the shortcut properties to %USERPROFILE% in the shortcut, or change those environment variables appropriately before starting Houdini.
