Variable in Path name
   1390   2   1
i am trying to copy a subnetwork which contains Parameters with relative References.
for example a seed parameter with ch("../../../Control/seed")
How can I insert a variable in this path like ch("../../../Control/seed$VAR") where $VAR is a integer number. This Variable i want to set by a parameter from outside, so that when i copy and paste the subnetwork i only have to set the Variable once and dont have to adjust every single channel path.
It does work with $F, so ch("../../../Control/seed$F") becomes ch("../../../Control/seed1") at Frame 1. That is exactly what i was searching for.
I Hope this was somehow understandable
try this
ch("../../../Control/seed`$VAR`")
tamte
try this
it works, thank you!
