Hi Everyone,
Is there a way to override global time in a scene?
Thanks in advance,
Mate
Global, scene-wide time override
1865 1 0-
- gadfly16
- 65 posts
- gadfly16
- 65 posts
I solved the problem, but I realized that the question wasn't very accurate. So my problem was that I wanted to render a scene file with a global time warp. Finally I did it in PDG. I generated a file range with the desired number of frames, then with a `generic generator` remapped the `Frame` attribute to the warp curve by `chf`, than I rendered the remapped work items with a `rop fetch`. Of course `$F` was changed to `@pdg_index+1` in the output file name.
This works like charm, if you have subframe interpolation, which I had because of motion blur anyway. (Volume caches need extra love) The only thing that's worth mentioning that you shouldn't generate a `range` attrib. This defaults the rop fetch to work from the `Frame` attrib, but results in one frame batches, which can be less than ideal if you want to render the sequence locally.
Mate
Mate
