Hello guys.
I have a very small source to emit smoke from so I scale it up and simulated it. It worked ok. Now I need get the sim back to size that the original source was. How do I do that?
Scale up and down a smoke simulation
3434 4 1-
- nelpiper73
- 80 posts
- tamte
- 9384 posts
- nelpiper73
- 80 posts
- tamte
- 9384 posts
nelpiper73right
I tried that but the sim disappears
you also need to make your volume denser since density accumulates over distance traveled within the volume
so the smaller the volume the less will accumulate and therefore the volume has to be denser for you to see it the same
so wherever you are setting up the look (on Pyro Post Process or in the Pyro Solver Look settings itself) make sure to increase Density Scale and Intensity Scale proportionally
Edited by tamte - March 2, 2022 00:57:56
- nelpiper73
- 80 posts
