RDB configure - set active by bounds
   2428   2   1
Hey everyone, in the test example file I'm posting I'm trying to set RBD active by bounds with the new RBD Configure sop. What am I missing? Setting RBD active on/off works fine, but the moment I turn on Use Bounds I get nothing.
What I'd like to be able to do is set the active attribute dynamically per sim timestep, I'm at a bit of a loss on how to do this with the new RBD
sop tools. Thanks for any help!
Edited by AndyW - March 4, 2022 15:07:23
RBD_setActive.hip (1.0 MB)
Hello.
You did everything correct except that connecting the active pieces to inactive ones by glue constraint which is a rigid constraint therefore they won't collapse.
Try changing constraint type to soft for instance can let the active part collapses.
Hope this helps!
Edited by N-G - March 5, 2022 14:56:24
D'oh! Yes super helpful, thanks
