Best (easy, stable) farm scheduling?
   1567   0   0
Hi, am about to setup a small farm(sub 10 nodes) for processing and rendering from a pdg network. Basically I will be loading parameter settings from a csv file and then use these for rendering (using vray) as well as writing out som metadata as a json. This works ok on one local workstation so now I wonder what the best approach for distributing this to a farm would be. Tried getting deadline to work but I only even got it to render locally using h18.5. Does anyone have a suggestion on what would be a good approach? Also, I am new to using farms so I don’t really get what licenses I would need. I assume there will be a need for Houdini engine installed on the nodes together with the vray plugin.
