create a list of attributes from geo/lops in tops?
   2171   2   1
I'm trying to create a text file with a list generated from attributes created at the geo and lops level. Is this possible to do with csv output or textoutput (or anything) in tops?
Playing with those 2 nodes I seem to be able to generate a text file list of attributes, but only from things created at the tops level not from any of the other levels. Is there a way for me to get the attributes from geo or tops into lops?
Edited by mhspadez - April 6, 2022 15:57:27
You can use a Geometry Import TOP to create work item attribute(s) from a SOP node, or a USD Import to create them from a LOP node. Then, feed that into the CSV or Text Output.
this is perfect, thank you!
