Extract transform
   1520   2   1
i have a library of packed primitives with a unique name attribute that i import, copy and transform, and mirror.
I need to extract these final transforms to export a json. Is there a way to do that?
Usually i have the orient attribute that helps me to generate a 3x3 transform but in this case i don't have any other attributes other than the position. The mirror sop doesn't output any transforms
Each packed primitive has "packedfulltransform" intrinsic attribute (4x4)
Or "transform" (3x3)
I'd recommend getting the former one though and that contains actual full transform
matrix xform = primintrinsic(0, "packedfulltransform", @primnum);
tamte
how would i use this in this simple example?
a lot of the values inside the 4x4 seem to be the same actually.
the copy to points is there just to see if it is correct but i guess i need an orient attribute to do that?
its not necessary, what i would like to know is if the "packedfulltranform" attribute is all i need.
Does that include the mirror operation?
Edited by papsphilip - May 1, 2022 16:53:17
extract_transform.hip (213.1 KB)
