Particle system cut out 10 frames short.
   1643   2   0
I have a particle system, I had to extend the scene by 10 frames. Now the particle ends at the old-time length, 10 frames short.
I can't find where I can extend the particle system to cover the extra 10 frames. How can I Get the particles system to add the extra 10 frames?
if you cached it before, you need to extend the file cache range by 10f
if it's live then if you play from the beginning it should sim as long as it needs, there is no end frame on the solver, so as long as the lifespan of individual particles is large enough it will continue simming
Edited by tamte - May 20, 2022 12:07:12
Hi, Thanks for the reply.
